JoeDv Offline OP
I'm not sure if this post is better here or in the '55 forum, but it's a part on the engine, so...
I'm putting an overdrive trans behind my 235 in my '55 Bel Air. I have just about everything that I need, but I need to modify the throttle linkage to include a "paddle" that presses the kickdown switch. My intention is to fabricate something that's representative & functional, since I can't seem to come up with an original. If anybody has one of these, I'd appreciate a few measurements to help me fabricate one. Here's a scan from the factory assembly instructions;
I marked it up with some dimensions that I need:
[Linked Image from i897.photobucket.com]
The dimensions are essentially the length, width, height, and material thickness. Once again, any help will be appreciated.
Thanks, Joe
JoeDv, I got the measurements you need.
L = 1.450"
W = .850"
H = .275"
From the top of the rod to the top of the paddle is 1.080"
The paddle is 90 degrees to the rod
metal thickness is a little over 16 Gauge
Hope this helps. You'll love the overdrive!
Jay
JoeDv Offline OP
Jay - thanks for going to the trouble to get the measurements. It will really help. This kind of stuff really makes VCCA valuable!
Joe
Your welcome, glad to help.
