Anyone have any ideas on removing a stubborn wheel hub ? I want to inspect my brakes on my '32 and need to remove all wheels. It's unknown how long they've been on, but after some moderate banging with a wheel puller, no luck. I then tried Bill Barkers' trick of tightening the lugs on the stuck wheel, then jacking up the other side and pushing on the car to try to pop it off. No luck. Maybe I'm missing something. Hung up on the backing plate somehow ? A ridge in the drum from shoe wear ?
My puller has 3 gripping legs, not bolt-on legs, so I didn't push it for fear of damaging the lug bolt threads. I tried 2 steering knuckle pullers they don't fit over the center raised hub and the bolt pattern doesn't line up perfectly. Any ideas out there ? Heat, dynamite ?
I've heard tales of farmers removing the axle nut on their tractors, then go for an exciting ride on a bumpy road. I'm not at that point yet ! Close ! Thanks all.
