Posts: 84 |
I have a new clutch disk everthing same as the one out of my 37 but the input shaft 1 inch. It is in a old GM box with no part number. Thanks The Honer
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Should have some casting numbers on it, that would help to identify it.
"input shaft is one inch"..? long, diameter, ...splines the same? There were no cast parts on a clutch disc or ID numbers....Infact Chevrolet did not even make clutch discs.
Posts: 84 |
Dia. yes it is 10 spline it is all steel but the friction part has GM printed on it. It is in a Everything that's good for your car, Gm Genuine Parts box the edges of the box are shot where the part number would be if not made by GM made for GM as where the forged pistons made by TRW for GM In the high performance 327 &302 Z-28 and a lot of the BB Chevy my father worked for TRW as I did he was with Ramco Piston Rings I just worked in a branch warehouse in Charlotte N.C. The Honer
OOps somewhere in my brain I thought it was a transmission.
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
1933-34 Standard clutch disc. is my guess.
That was my thoughts. Over the years you could't give the 1933-1934 Standard parts away.....unlike today.
Posts: 84 |
Thanks for the info. I kinda thought it was for a earlier model.
The Honer
