#338541 03/30/15 10:41 AM
oboy Offline OP
trying to remove to chrome rings for the door handles off the outer door skins.Any tricks or do you knock them out and get new ones?
Wake up to learn something new everyday.
.....do you knock them out and get new ones?
Yes. Also, there is a special tool that you can rent from the Filling Station to install the new escutcheons.
oboy Offline OP
Thanks kinda thought that try ed one and the 4 dimples left nice dents in the skin.So I'm going 2 try drilling them first to lighten the damage.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
If you're working from the inside of the door, use a small screwdriver, or punch and bend the "ring" inward. Do this all around the "ring" and that will move the dimples away from the skin - then you can just push it out without any damage to the door.
PS. The "rings" are called ferrules. computer
oboy Offline OP
Thanks I'm going to try drilling each one from outside first the dimples are close enough to get to them.Then I'll pry the inside.tough little buggers.
oboy Offline OP
And would like to thank chip b in Asheville for letting be come over and look at the 30.Your new mail car is looking gooood!
