#338460 03/29/15 01:49 PM
I was told by a person on another site that Chevrolet truck carburetors on the 216 engine changed to a "high cover" between 1951 and 1952 model years. I took this to mean that the top casting had a higher neck starting in 1952. Is this right? And if so - does anyone here have a picture of the "correct" 1952 carburetor? Any help appreciated.
Former Director, Heart of Georgia Region VCCA
1953 3100 truck, 1965 Impala SS, 1965 Chevelle SS
the bowl cover was made higher (thicker) around the outer edge requiring longer screws. Had some internal improvements also.
The 1950 and 1951 low cover carburestors tended to be troublesome on some cars. In late 1951 the new high cover carb. was factory installed on Power Glide 235 engine cars. In 1952 ALL engines got the new and improved carb. On earlier 216 and 235 engines having problems high cover carbs. were installed under warranty to keep owners happy.
There are pictures in the 1949-1953 shop manual for both.
Just noticed your message again. I believe I am the one that made the "post" on the other chat site.
With your email address I could send you the manual pictures.
Thanks for the info. The top picture shows my current carburetor, and the other is (I believe) the one I need to find. At least, it appears consistent with the section view in the 1952 shop manual supplement (which I somehow missed when I was putting the truck together). Does this look right? I appreciate the help; I'd like to get it right.
[Linked Image from lymanhall.smugmug.com]
Is the throat diameter the same, or will I need a different air cleaner?
No, it is a low cover 19500-1951 unit. I sent you some pictures.
You may want to speak with Doyle Stokes, down in your area.
After 1952 if you purchased a new carburetor from Chevrolet it would be the later high cover design regardless of the year of your car.
Is the Rochester Model B Carburetors a significant improvement over the Carter W-1's on the 216 engines? I know that the Carter W-1 carb seems to "boil out" the gasoline after you stop.
dtm
the toolman
VCCA # L 28873
They all have that problem.
The best W-1 is the 1941-1948 model with the 1949 still better.
They are too lean for 1937-1940 engines causing a surge at mid speeds.
I tried them all on my '39 and the original carb. worked the best.
The Rochesters got better through the years also with the "about" 1955 and up the better of the bunch.
Gene, where did you send the pictures? I'm trying to find the right carburetor and my "sources" all want photos. Thanks
I sent them to you yesterday. have a new cp and went from Windows XP to Windows 7 and things don't always work right.
Will redo.
Please get back to me.
Nothing yet. My e-mail address is:
vvwca@mindspring.com
Thank you again
Bob, I spoke to Doyle, and he has asked for a picture. I appreciate the lead.
I was using a yahoo account.
I now forwarded FOUR emails that I sent.
Let me know if you get all four.. Your filter may be holding some out.
One has my phone number, feel
free to call.
You're welcome. dance
free to call.
Gene, nothing there and nothing in the "spam" filter. Probably some issue on my end. Any chance you can post the picture here on the forum?
Thanks again
Thanks for the phone call, Gene. Now I know what I'm looking for. I appreciate the guidance.
