Posts: 229 |
I have been using the Champion D16 spark plugs for some time. Around town 30-35 mph it works fine. I have the engine timed according to the "revised specs" provided by the VCCA web site. At 45-50 mph, the car begins to ping and I have to pull the retard knob to reduce this noise. Would changing the plugs to a colder plug help reduce this pinging? If so which plug should I consider using.
Posts: 229 |
I tried to look for the AC Delco c86 plug. The cross references are the following:
Autolite Copper Core 386
Champion Copper plus D14 or box #514
Motorcraft BTS-8
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
JYD, quick question. With the AC-C87 plugs, is the gap still .40 and the timing 18btc? I am going to a complete tune up as part of completing my 31's restoration. If I can't find the C86's I figured I'd ask now about the C87's.
From my post above on March 28th: Change to either the AC-C86 or AC-C87 plugs and see if that makes a difference. The plugs should be gapped at .040" and the timing should be set at 18 degrees with those plugs.
