#33798 09/29/06 02:30 PM
Hi, Where can I obtain polyurethane bushings(either black or red) for the 1-front stabilizer sway bar links and 2-rear spring rear spring shackles? Dimensions 1-1"OD, 5/16"ID, 21/32"High, 2-Body OD 27/32", Flange OD 1 1/4", Flange thickness 1/8-3/16" , Overall height 1", 1/2"ID. I have Prothane's catalog and they don't show either. Thanks, Larry
#33799 09/29/06 02:38 PM
I would suggest keeping the rubber ones.The poly ones will squeak after awhile and are of no advantage except the rears will transmit more shock and vibration.
#33800 10/02/06 02:03 PM
I found these bushings (not sure if they are natural rubber or poly, I assume they are synthetic) available over the counter at the local family owned parts store as part of a kit that included the bolts and other related hardware. I think it was a Bosch kit, but it's still a catalog item. Find a store that's been around a while w/ experienced help. Bowtie
