Posts: 275 |
Hi Guys, I think my 29 engine is touching the firewall because of failed rear motor mounts. It seams as if the rear mounts are rather thin canvas strips. Is that correct? Do the Chevies also suffer from frame sag as the Model As? Any suggestions please gents Regards Chris
Regards, Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC
Posts: 956 |
Hi Chris,
1929 has metal to metal mounting, no materials.
Roger
It seams as if the rear mounts are rather thin canvas strips. Is that correct? No. The engine and transmission are bolted directly to the frame. Do the Chevies also suffer from frame sag as the Model As? While the 1929 frames are not the strongest frames in the world, I have never seen a 1929 frame that has sagged.
Posts: 93 |
Chris,
I ran into a similar problem that was caused by the front body mounts breaking loose from the body. It caused the firewall to tip forward. It gave the truck a swayback look. Chevrolet offered braces for the firewall to help prevent this problem. After fixing the mounting pads and adding extra support, the swayback look was gone and everything lined up properly.
ArtM
Posts: 275 |
Tks Gents, Appreciate your help. Regards Chris Cape Town
Posts: 275 |
