I am looking for oil seals for the axle shafts on my 36 standard two door. I called Olcar Bearing Co in NC and the guy said he would check and call me back, that was a month ago. I have heard nothing.
I texted my request to South Shore Bearings in MA. That was also a month ago. No reply.
Any recommendations?
The rear axle seales for a 1936 Standard also fit all Chevrolet passenger cars from 1937-1954.
Go to NAPA and order a pair of axle seals for a 1954 Chevrolet make make things more simple.
The new seal will look different from the originals(improved design) but the dementions will be OK.
AWSOME! Thanks Gene. Should have emailed you first.
Kim
Also carquest , Give them the # from the old ones, I had them the next day at $14 each .
easymoney
Black Bird,
It's a common, inexpensive SKF seal # 15557. Even in the rural area where I live the local bearing and hydraulic parts outlet had a box of them. They must fit farm implements too.
