Does anyone know offhand the dimensions for the fan-belt on a 1936 205Cu in engine? I would like to buy a spare without removing mine. I found a site that sells them by dimension only. Thank you.
J Franklin
The Filling Station has new fresh belts for $14.50.
Engineering specs manual says 39-3/4" around outside and 11/16" maximum width.
It would be helpful to others, if you shared that site information.
This is the site and they list Kevlar belts made in the USA.
https://www.glenssurplus.com/categories.php?cat=33
J Franklin
