Whats a good company or brand to use for a ifs
KUGEL KOMPONENTS in calif is top quality. Lots and lots of people use FATMAN systems.
Normal is rear steering behind the new fatman cross member. Sits down lower in that area even with the cross member.
If it was front steer you'd never get the steering rack head to show so you could hook up the BORGESON steering JOINTS.
Tight tuck headers are a must and borgeson steering joints with center HEIM joint support = ( spherical rod end ) 3/4".
keeping in mind that 35 degrees is maximum deflection before binding occurs in a single center joint system , from steering column down to the steering rack assembly.
mike...................
