#33669 06/28/06 06:40 AM
mark47 Offline OP
this is weird but when I am in second gear under load as in going down hill and need to brake the brake pedal has some resistance and then brakes free, the gear lever moves and then I can continue to brake. It is as if the brake pedal hangs up on second gear linkage. When I looked under the car and put it in second gear then brake the pedal does not hit a thing. Any ideas would be greatly appreciated. Thanks. mark
mark47
#33670 06/28/06 08:03 AM
Check motor mounts
