Thanks for your reply Chev Nut.
I have the '37 manual and its' only reference to a dimension is 0.010" clearance for the second gear end float. I have 0.013".
I have several 2nd gear thrust washers , all measure 0.115".
also several 2nd gears , all measure 1.888" long.
All the second gears have worn teeth.
All energizer springs show polish but no wear.
All input shafts have worn teeth and front bearings are loud.
All needle rollers (input-output shaft) measure the same and are undamaged.
There is just a little wear on the main cluster bushes and some end float also.
Shifter forks have small wear , what is acceptable clearance?
I would really like to buy a new input shaft , syncro drum and second gear , but have been unable to source these.
I have read the later manuals , same info supplied as the '37.
