Posts: 44 |
I have a 36 FC with a broken axle housing, it was welded (poorly) when I bought the car and broke last fall. I found a replacement axle housing, but haven't located axle shafts and wheel bearings and seals. Anyone know where I might find these?
Posts: 2,299 Likes: 8
Posts: 2,299 Likes: 8 |
I have NOS axle seals and a NOS differential case and maybe other things if I look around more. E-mail me if still needed. bwbugay@aol.com
The rear wheel bearing race and rollers also fit 1937-1954 cars as do the seals. Try NAPA.
Posts: 1,381 |
George @ OLCAR BEARING 910-693-3324 No. Carolina
Posts: 44 |
have the bearings located, any idea where to find axle shafts?
Posts: 1,381 |
Ask George, also ebay Ebay listings - 360669930976 and 121441139371 And # 121441131826 and 270365846855
Bruce is a good source too. (Posted above chevy b)
Posts: 406 |
The first and last ebay listings are for a Master.
Posts: 1,381 |
Just a quick search. Send sellers a question or request they may have other parts.
Why do you need axle shafts???
Posts: 44 |
when the weld broke on the axle housing the splines took the weight and the c retainer clip shoulder broke off the left axle shaft. The right one looks good. I appreciate the care and lubrication the previous owners applied, parts are much easier to remove than my '96 suburban. 60 years newer, but very hard to tell from underneath.
One good thing is the right and left are the same so if you find only one it will fit either side.
Posts: 1,478 |
Check out bwbugay@aol.com I have used him before. He is very good. This is the place to come to for '36 Chevy Chat. You will find all the answers here!
