Posts: 3,163 |
I just realized the 3 prong plate that goes to the top of the coil from the electrolock has the 3 prongs cut off. Can that plate be replaced? Thanks, Joe
Posts: 3,163 |
Ok. I'll give that a try. Now to get the old cable out of the replacement part. Thanks, Joe
Don't forget to remove the internal wire from the electrolock cable before attempting any type of repair to the end cap. Good luck!
Posts: 3,163 |
It's getting replaced for sure. Kind of crusty. I don't need my restoration to go up in flames. Thanks, Joe
