#333038 01/30/15 09:48 PM
bucket Offline OP
does anyone know if there is a company making the tops for a 1931 Chevy I/2 ton Roadster pick up. I have checked with Hampton Coach with no luck there. Thanks Bucket
Steve ODaniel
bucket #333130 01/31/15 09:32 PM
None that I know of currently. The Boss will be making one in a month or two. Should get the '31 Roadster pickup from the Body Shop in March.
Chipper #333146 02/01/15 12:20 AM
Does Hampton Coach no longer make tops for Roadster Deliveries.
I checked with them a couple of years ago and they said they didn't keep the tops in stock but would make them once an order was received.
dandyd #333168 02/01/15 10:55 AM
Don,
Hampton Coach might have the top pattern for the 1930 RD but not the '31. The tops are similar but different. The other problem is that the correct top material is not available.
