Except for the front door skins and dash which are wrinkle brown, The original interior color is a yellowy brown.
Do you know where I could get this color?
Note the door check on a 37 is just a strap where later 37 and 38 has a rod and bumper.
Above is my 37 half ton.
Same color inside the yellow half ton Canopy.
Bulkh 41
Bulkh 38
It's starting to rust.
My ambulance also has the same interior color. The doors and dash are wrinkle brown.
975 rr Note the newer door checks.
971 Roof uph.
There's a piece of upholstery that goes between the roof metal and top bows.
How would I slide it back in there?
My questions are about photos that I can not get to load.
Thank you, Lou
