Last year I installed a generic throttle cable and knob to get my hand throttle working on the 48. Tonight, I dug out the old 48 knob, and, figured I'd finally replace that ugly black knob on the dash. I figured out a slick way to get the old knob off its shaft. I clamped a pair of visegrips to the bottom end of the knob's shaft, and, heated the shaft about midway with a fat votive candle. In a couple of minutes, I was easily able to pull the old knob off the shaft. I then pulled the black plastic knob out and clamped my visegrips on its shaft so it was sticking out of the dash a couple of inches. I used my Dremel and a cutoff wheel to slot the knob down the metal shaft inside, then I was able to use a flat blade screwdriver to spread it and break it off. Luckily, with the shaft secured by the visegrips, when I pushed the original 48 knob on it fit nice and tight. Had it not, I'd have used some epoxy glue to secure it. Now, all my knobs match again, and, I got her done in less than 30 minutes. Hope this helps some of you.
Regards:
Oldengineer
