Hello Everyone,
Reading about doubling up fuel filters and using the see thru type plastic ones, reminded me of the time after fueling my motorcycle at the convenient store gas station one evening. The next morning, with a full tank, I headed out for work on the bike. After a couple of miles I arrived at the stop light next to the same convenient station. While waiting for the light to change, I got the strong smell of fuel. I looked down both sides of the tank and saw fuel pouring over the motor. I hit the kill switch and pushed off to the side of the road. Having a vacuum style petcock stopped the fuel with the motor off. I searched for the source of the leak. All the fuel lines appeared ok and the inline filter did too. Going to the other side of the bike to look I saw that that side of the plastic fuel filter was melted thru. It was not due to a heat issue and I had installed the filter months before with no problems. It had to be the fuel bought the night before. I changed to a metal and glass serviceable style inline filter from then on. I never bought fuel at that place again and would not recommend using plastic fuel filters for anything.
I managed a Chevrolet Service Dept.
As an addition to our business, we had a Motor Home franchise, as well.
Chevy frame and operational driveline were sent to Motor Home assembly plant, for installation of Motor Home body, etc.
Motor Home Co. always installed an additional inline plastic filter, between fuel pump and carb. 350 and 454 engines were used. Class A and class C bodies were used by Motor Home Company.
Once sold, and on the road, I cannot tell you how many incidents occurred, where the rubber attachment hoses would either split or break off the plastic/composite nipple of the plastic/composite filter body.
Results were gas smell or engine stalling out or engine bay fires, fires that could and did spread throughout the motor home body.
A very good reason not to use ANY fuel filter that is not mounted with a hard line and fitting attachments to the metallic filter body.
