#331331 01/14/15 01:00 PM
the39 Offline OP
I have my master 85 gearbox out for a rebuild . I did get john deere corn head grease @ 3.75 a tube . and from chev of 40 I got a rebuild kit with 2 new bushings ( steel shell on outside - brass lined inside )I also bought a n.o.s. pitman arm . it came with 2 new - all brass bushings . should I use the steel or brass bushings ? frank
the39 #331363 01/14/15 05:06 PM
Either one should be satisfactory. The lubrication is the main thing.
Chev Nut #331623 01/16/15 03:22 PM
the39 Offline OP
HI GENE ,I got the two bushings reamed out with a brake hone . the manual says nothing about the cork gasket seal ( between the two housings ). install it dry ? or a little grease ? thanks frank
the39 #331628 01/16/15 03:56 PM
I would use a thin coat of chassis grease on the wearing surfaces. Then when installed in the car fill the housing with a mixture of 1/2 chassis grease and 1/2 transmssion gear oil.
