Posts: 67 |
Can someone tell me the weight of my 32 Standard. My reprint of the owners manual has left it out, and I am looking to buy a trailer. I am thinking it is about 2800 lbs. Thank You
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
That is probably close for a standard sedan. Is your car a sedan, coach, coupe or roadster?
Phaeton 2520 Landau Phaeton 2700 Roadster 2410 Sport Roadster 2480 Carbriolet 2590 Standard Sedan 2750 Special Sedan 2800 Coach 2665 Standard Coupe 2580 5-Window Coupe 2580 5-Passenger Coupe 2700 Sport Coupe 2645 When asking questions about your car please be specific as to which model you have because the answer could vary from model to model.
Posts: 1,919 |
Hey Terry,
If I remember right, when pushing your car last fall, it weight about 2800 pounds. That was what my arm gauges were telling me.
I would used 3000 pounds when buying a trailer, use some safety factor. Also the bigger the breaks you can get the better. So if you get the bigger capacity axles, you will get the bigger breaks.
Bruce
