mark38 Offline OP
38 two door master... I have new glass and run channel in my quarter windows... window will not roll up with run channel in place. rolls up fine without. It binds at the rear corner in the channel. Any help. Thanks
Sounds like the glass is not correct. I would make a pattern out of hardboard that can be trimmed and once you have that working ok have the glass trimmed. Check to be sure the run channel is seated properly first. It's a lot easier to trim the hardboard than the glass.
Use a narrow board ( that fits the channel) and reset the channel on both sides.
