Posts: 19 |
I've got a question about engine parts casting numbers. I have a 28 engine and head, the flywheel casting number is 344100, dated B-5-7. I have another flywheel that is stamped 363016, dated L-14-3. The last one has a thinner ring gear. Is that date for 23 or 33? The number is so much higher than the first that I'm thinking it might be 33. Is there a source of casting numbers that I can look up? Any thoughts on this will help.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
There is an online parts manual for 1916 to 1928 parts. Click on the link. http://chevy.oldcarmanualproject.com/parts/1916_28/cp4cm14.htm Lists 363015 which is 1 number off what you have posted. 344100 is not listed in the flywheel section, closest is the locating pin 344101
JACK
Posts: 19 |
Thanks Jack, I'll look thru that. At this point all the info I can get will help.
Beginning with my 1925 Parts List for Superior Models Series K dated Feb. 1925 to Chevrolet Master Parts Price List dated Aug 1930 list P/N 344099 as the flywheel for Superior K and later four cylinders. My parts books beginning Feb 1931 show the P/N 363015 as the flywheel for four cylinders. It is common for part numbers and casting numbers to differ by a single digit.
My conclusion is that for some reason flywheels cast and supplied after 1930 had a different number. Therefore your flywheel with casting number 363016 was a replacement cast December 14, 1933. The other was cast February 5, 1927.
Posts: 19 |
Thanks Chipper, that makes sense. Another question is there are no timing marks on the 344100 flywheel, how do I go about setting the timing when I get ready to install the distributor? Thanks for your help.
Check for the marks on the 363016 flywheel and transfer them to the 344100 flywheel. I haven't used a timing light in years. Just time it to the max. idle speed and then double check with spark advance/retard lever. If the idle speed slows noticeably then retarded and has smoother idle when advanced it will be okay.
Posts: 19 |
Thanks again Chipper, all the help and info I can get will help. I'll try to keep you posted on progress.
