#32918 08/24/05 01:13 PM
Hello again, there is a pan welded on the underside of the drivers floorboard. It resembles a shelf almost. It is definitely a factory installed piece. It doesn't seem to have a purpose. Does anyone know what this is for? I discovered the car did have vacum shift at one time, as I just removed the air cleaner from the frame. Maybe there is a correlation?
Thanks again,
Wenatchee Walt
#32919 08/24/05 03:24 PM
Would it be above the muffler??Is it a heat baffle welded to the floor?...I don't recall if these models had one but that would be my guess.
#32920 08/24/05 04:18 PM
yes it is a heat baffle for the muffler .have a body manual for this year shows it in place. kozy
Tom Koziol
#32921 08/24/05 10:51 PM
thanks that makes perfect sense.
Walt
