Posts: 89 |
I'm currently rebuilding the running boards on my 1925 Chevy. I need to know if the two bolts going through the rear running board frame bracket are are exposed or if they are covered by the rubber matting material on the running board itself.
1925 Chevrolet Utility Express PU
Posts: 88 |
They appear to be not covered by the rubber mat on a picture I have.
Jim G
Posts: 324 |
I have seen both. However, in my review of all factory photos I can see no visible bolt heads. I used elevator bolts on the two rear brackets and covered them with the mat. I think it looks correct. However, Im sure you will get diffing opinions here from some of the more knowledgeable.
Posts: 89 |
Thanks guys for your input. I don't know which way I'll do it yet but I like the idea of using elevator bolts instead of the carriage bolts.
Posts: 1,049 |
Guys and Gals top pic my 27 sedan with correct rubber on running boards lower pic my 27 touring with incorrect rubber some day I will put new on both. Ken ![[Linked Image from s2.postimg.org]](http://s2.postimg.org/si0z7335l/WP_20141221_004.jpg)
I have a 1927 Chevy Capital AA 4 Door also a 1927 Chevy Touring car, a 1936 Chevy 1/2 ton and a 2010 Corvette LT3 Convertible and a 1953 Packard Caribbean. My tow car is a 2011 Suburban.
Posts: 89 |
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
Rich W my '25 doesn't have any bolts showing.
Posts: 1,049 |
I am thinking 400 bucks or so will get you new ones
Posts: 89 |
Ken, I'm going to try to make new ones. I have enough wood on the running boards for patterns.
Posts: 1,049 |
here is temp option
http://www.ebay.com/itm/220811528259?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Posts: 1,049 |
Posts: 89 |
Ken, I found that Lowes sells the correct small ribbed pattern rubber. I bought some years ago and I plan on using it.
