#328196 12/15/14 08:20 PM
I'm trying to remove the shift knob from the shift handle on my 33. I realize it just threads on but this one is really stuck. I don't want to ruin the knob or the handle. Before I pop a vein in my neck, anybody have a suggestion? Thank, Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
jiaccino #328200 12/15/14 08:53 PM
A small amount of heat??? perhaps heat the top of the lever.
jiaccino #328206 12/15/14 09:46 PM
Try one of those rubber strap thingys that are used for removing jar lids and etc.
Thanks. I'll give those ideas a try. Are the knobs bakelite? Thanks, Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
jiaccino #328218 12/15/14 10:57 PM
I believe they are hard rubber with a brass bushing (threaded).
jiaccino #328226 12/16/14 12:03 AM
I have some new old stock gearshift knobs for 1931 and 1932 and they appear to be Bakelite with a threaded insert. The replacement knobs were made of hard rubber and there was no threaded insert...it was a push-on knob instead.
The push-on knob began in 1934. There was a rubber insert to grip the rod.
jiaccino #328527 12/17/14 11:45 PM
I had to just break mine off with a hammer and purchase a new one from the filling station.
Krugerbenz #328543 12/18/14 07:02 AM
I'm trying to avoid that. over the weekend I will try boiling some water & just putting the knob end in for a short spell, (don't tell Sheri)...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
jiaccino #328683 12/19/14 12:35 PM
Place the shifter upside down & make a"cup" around the base of the knob with tape' Fill the tape with penetrating oil. Wait. See what happens.
Pat S #328871 12/21/14 06:40 PM
All of the above seems like goods ideas. The heat can come from a Hair Dryer. Worked for me and it was safe.
Good Luck
41Michael #328904 12/21/14 10:36 PM
I got it removed. It took soaking it with penetrant, some heat & a strap wrench to remove it. I still almost popped a vein in my neck. Thanks everybody...Joe
1968 Z/28 Camaro
1969 SS 396 Camaro
