Posts: 88 |
I don't have a owner's manual for a 1925 Superior K. I see that the retard position is opposite on a 24 then for a 28. Where should it be for the 25?
Jim G
Posts: 1,623 |
Retard is up. Follow the linkage rod from the lower steering column over to the distributor, and you can see which way it moves the distributor.
Chevy Guru
The location of the throttle and spark levers may be found in two locations. On the early 25s the controls are under the steering wheel on the steering column. The later model has the two controls down on the dash. In both locations the direction of the controls are marked.
Posts: 88 |
Jim G
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
Jim31Chev, at the 12 o'clock position under the steering wheel it is full retard, on the dash it's full advance at 12 o'clock position.
