Posts: 168 |
Have a 37 with a bad wire in the armoured cable leading from the keyswitch to the coil that needs to be replaced. How do I do that??? It looks like the whole thing is non serviceable. Thanks in advance for any suggestions
Posts: 822 |
Ryan,
If fixing the old one doesn't work out I have a NORS "Electrolock" with keys left over from the restoration of my '36 pickup in the 1970s.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Have a 37 with a bad wire in the armoured cable leading from the keyswitch to the coil that needs to be replaced. How do I do that??? It looks like the whole thing is non serviceable. Thanks in advance for any suggestions It can be rebuilt. The Filling Station sells a rebuild guide for that Electrolock.
Posts: 373 Likes: 1
Posts: 373 Likes: 1 |
I recently did mine. It was a little easier than I thought. Here is a link.
https://vccachat.org/ubbthreads.php/topics/324055/Re:_Another_Electrolock_Questi#Post324055
VCCA Member 51121
