Posts: 31 |
I need to remove the bezel from my 40 dome light, so I would appreciate any suggestions as to how to do this without breaking it.I see there are no readily available replacement parts for the 40, so i was wondering about the switch, which is broken on mine.There is a small hole on the front side of the bezel which i am assuming was for the switch assy, as there are no door switches on the 40, according to my wiring diagram. Any help appreciated. Thank You
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Posts: 31 |
Thank You for your reply. Yes, my 40 is the same as yours. I now know what the small toggle switch under the dash is for. The dome light now works fine.
Posts: 596 |
It looks like there are three different dome lights for the '40; round '34-40, rectangular '37-52 and rectangular '40-'48. I suppose it could have to do with where the car was assembled and what they had available. My two door has a rectangular light with a slide switch on the passenger side pillar.
Richard Waverly, IA
There were two different 1940 dome lights. The Master 85, Master Deluxe (all body styles) and Special Deluxe coupes had a round light same as 1935-1939 models that had the switch on the light. Then there was a square lamp, it was used on 1940 Special Deluxe sedans and 1941-1948 Master Deluxe/Stylemaster sedans. The long narrow lamp with a point on one end was used on 1941-1948 Special Deluxe/Fleetmaster/Fleetline models.
Posts: 415 |
Say Tiny, can I ask what # that bulb is you have for the dome light? Thanks, _______________________ Joe's 37
Say Tiny, can I ask what # that bulb is you have for the dome light? Thanks, _______________________ Joe's 37 #87 I believe. It fits but it's close to the lens so you don't want to forget & leave it on. 15 cp I think. Sure helps these old eyes see in the dark.
Posts: 415 |
I hear you on that old eye thing! Now that the NightTime ice cream runs to Dairy Queen in Grandpa's "OLD CHEVY" are over, I'll put one of those's #87's in there. The grandkid's always wanted that light on---it looked neat???? Thanks agin Tiny, ________________ Joe's 37
Always happy to help when I can my friend.
Posts: 929 |
Thanks for the advice. I was trying to remove my dome light cover thinking it might rotate and release, but now i see i just pull straight down. My 38's dome light cover does not have a screw to secure it to light assy. I didn't want to ask a questions that was answered already so I had to search, but did find my answer. Funny how the answer came from a 1940 question, but answered from a 1938 Thanks again, Mike A
The screw looking thing hanging down is the knob of the on/off switch. Pull down for on, push up for off.
Posts: 929 |
My switch is on the pillar. Is that a hat holder peeking into the picture? Mike A
Yep, used to have it mounted but now it's hanging on the wall of the garage.
Posts: 929 |
I will end up picking one up because i do wear fedoras so it will be used. Mike A
Posts: 1,441 |
It must be nice to have a dome light,my 37 p/u did not come with one and I do not think one was ever offered for the trucks but I have one that I think came from a panel truck that wil be going in when I redo the interior.
VCCA #45194
Posts: 373 Likes: 1
Posts: 373 Likes: 1 |
Here is the hat holder in my 38 Master ![[Linked Image from i10.photobucket.com]](http://i10.photobucket.com/albums/a143/modiol/20150117_131548_zps4vsqmc5a.jpg)
VCCA Member 51121
Posts: 929 |
Nice, Did you ever find the trunk support spring for your 38? Do visit chevybombs.com? I'm on it often. Mike A
