#326683 12/02/14 09:26 PM
regmudd Offline OP
I've just put my rebuilt 216 back together in my 1939 Master 85. We're in shakedown mode. After noticing it running rough, we pulled the valve cover off to find not much oil in and around the valves. Is this typical or is it symptomatic of something else? Valves appear to be a little loose but nothing serious. Thanks, RegMudd
regmudd #326701 12/02/14 10:23 PM
I don't know what you consider "not much oil" but with the engine warm and running it should be dripping hear and there and a stream comng out of the over flow tube in the center
regmudd #326738 12/03/14 08:57 AM
Do you have oil presure??
Did you prime the oilpump after rebuilding the engine??????
Jianis driving
JianisNl #326755 12/03/14 12:17 PM
The oil line could even be the problem? In the rebuild process how was it cleaned? Does it have a kink in it where it comes out of the block and bends upward? I've seen oil lines that looked like they had a lot of crud in them. I got new lines as part of my rebuild. I'll see if I can find a picture of a suspicious line partially coated with crud, and post it.
You could even have a pump issue where a gasket might be missing. I think Gene has commented on the importance of the oil pump gaskets?
Here is a link to some posts on oil lines Oil Line
Good luck, Mike
