I am restoring a 1934 Coupe and need to know the details regarding fender welting and panel fitment for the rear fenders and the rear tail panel.
Can anyone provide good pictures of the fit of the rear fenders to the body and also the fit of the rear panel to the fenders?
Did the fenders have fender welt between the body AND the rear tail panel?
We see evidence that there was a beaded welt between the rear tail panel and the body.
Thanks in advance,
Tim Bowers
620-489-6495
www.stellarrestorations.com
Tim
Are you working with a Standard or Master?
Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
It's a standard Coupe. My fat fingers stated that it was a '34, but it's a '35. Things look the same, though.
Thanks!
Tim Bowers
Stellar Antique Auto Restorations
Jim only difference between a 1934 std and a 1935 standard is the frame: 34 is a K member and the 35 has the much stronger X member. The rad ornament is also different.
Back in 1979 I purchased a NOS gas tank cover panel for my 35 3 window coupe. It had all the holes across the top , which I assume was for fender welt. This would be to mask any differences in the mating edge shape of the body and the gas tank cover .
I found that the welting moved the cover out away from the bumper braces mounting ***cast brackets*** in the frame. Enough that doing up the bumper brace bolts would crush the cover in that area and distort it. You would have to place washers between the frame cast brackets and the gas tank cover panel.
To keep the welting in place I used a trim bolt with a flat 1/2" long top.
The gas tank cover toooooo the fenders is adjusted thru the 3 slots on the side that match up with the fender.
There is also a special bracket that mounts on the factory frame about 7" from the end, that supports both the fender and the gas tank cover panel. I actually had these reproduced with a flo jet cutter and brake . They sell for $15.00 a pair plus shipping by postal.
You need the running boards loosely mounted along with fenders and gas tank cover to align everything.
mike lynch Agrin
