We just rebuilt an aluminum 1964 Powerglide. Upon completion, we only have First Gear. Second and Reverse are inoperable. We only changed out the band, the clutches/steels, valve body gasket, pump gasket and Front and Rear seals. Has anybody ever experienced this, and if so, what was the remedy?
I remedied the problem for the record. There were gaskets in the kit that covered several versions of the Powerglide, and the incorrect gasket was used on the rear pump assembly, thereby blocking off the oil flow to the rear pump, which supplies the fluid to both reverse and high. Moral of the story is, don't rebuild your own transmission!
Been there done that
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
The 1966 and up did not have a rear pump and evidently that is what the gaskets were for. You would thnk they would have a warning packed in with the gaskets.
Actually the rear pump does not cut in until about 40 MPH. Before that the front pump supplies the pressure. When the rear pump cuts in it blocks off the pressure from the front pump. The front pump is sending presure to the rear pump and valve body at all times so the flow must be maintained.
The units with no rear pump can not be push started.
