Posts: 1,411 Likes: 7
Posts: 1,411 Likes: 7 |
This is a 350. The number stamped on the block front boss behind the water pump is: K0831PHC. Under that in a smaller font type is : CJ 710556. I'm uncertain about the 55 numbers. It appears the block was made in Ontario August 31st? If so, what year and for what car model?
Found additional numbers today. On a boss, drivers side near oil filter: 0 or O 1141694
Cast numbers: passenger side low on block. 350. A 1. Beneath that D 107
Drivers side. Low on block. 350. 24
Posts: 108 |
Produced in St. Catherines, Ontario (McKinnon Industries of Canada), August 31. From what I can tell it's a 1978 Pontiac 305cid, 145hp, 2bbl carb. That's for a PH block, they don't list a PHC.
The smaller numbers are usually the last portion of the VIN. The 'C' puzzles me, but the J = Janesville assembly plant, and the 710556 is the sequential production number.
Bryan Toedtli Hillsboro, OR
1937 Chevrolet Seagrave Firetruck 1938 Master Deluxe Business Coupe 1950 Belair 1964 Malibu
