I converted my 38 Chevy to 12 volt and wanted to keep the electrolock look on the coil. So this is what I did to retain that look. After replacing the wire inside the electrolck, I stripped all the paint off of the cable and cap. The previous owner painted it all black. I repainted the cap black, then clear coated the cap and the bare cable to keep it from rusting, we'll see how well it holds up in time.
I went to Home Depot and bought a can of HDX window and door lubricant. All I wanted was the can, not the contents. I searched a lot of cans, but this one was the correct diameter of my coil.
I cut the can down to 3 1/2 inches.
I had to grind the inside ridge on the bottom of the can so the electrolock adapter would fit into the ridge area.
I drilled a hole in the center of the adapter and another hole for the wire to go through. The adapter is held onto the can with a nut and bolt.
I also drilled a small hole on the side of the can so the wire can connect to the resister, then the coil. I used rubber grommets on both holes that the wire goes through.
Here is a picture of the assembly placed over the coil.
And here is the picture of the completed, and painted assembly.
Hope you enjoyed the article and I'm open to your opinions.
