Doing an Interchangeability Comparison for the 1929-1932 Head & Head Associated Components. Considering my 1929 head is some sort of hybrid being 1929 Head w/ some modern later Components. (Valves, Springs, etc...)
Doing some research on HERE and my 1929-1932 MPL. The Head Itself is basically interchangeable between the years of 1929-1932. More so 1929-1931 with the Rocker & Valve Assemblies, Since Big Changes for the 1932 Head. Looking for a 1929 Head to BUILD with STOCK 1929 Component, but open to other YEAR options IF they are feasible and acceptable to working WITHOUT Modifications. i.e can I use a 1930 Head w/ 1930 Valves & Rocker Assemblies on my 1929. or a 1931 Head w/ 1931 Valves & Rocker Assemblies on my 1929.
VALVES
1929 - Int & Exh Valves have Same Head Dia 1 11/32 (1.344)
1930-1931 - Int Valve Head Dia 1 29/64 (1.453), Exh Valve Head Dia 1 11/32 (1.344)
1932 - Int & Exh Valves Vary in Head Dia (not listed in MPL)
1929-1932 Keys, Springs, Cap, & Guide listed as Interchangeable
Not sure what Collar, Valve Stem Guide 835811 is ?? listed as Interchangeable
VALVE ROCKER ARM
1929-1931 - Arm Assy (Shaft, Bushing, Wicks, Support)
1932 - Arm Assy (Shaft, Bushing, Wicks, Support)
1929-1932 - Adjusting Screw & Nut listed as Interchangeable
1932 did away with Wicks, got new shaft, rocker arms, bushings, supports
VALVE LIFTER
1929-1932 - Lifter, Valve, Push Rod listed as Interchangeable
... ...(Was 2 Piece in 1929)
Maybe you need to get together with GreenBayPacker14 as you could use the head he has been posting.
I'm busy watching the Packers/Bears game in Green Bay tonight. Have to take a break from the car frustrations.
I'll post what I find out about the head and if it works.
I quit watching the game at half time. Felt sorry for the Bears. wow40 to 0
Score is better now....48 to 7
How did we get into football? bigl bigl
lol, I started to watch a Football game, or so i thought... called it quits at start of second quarter 21-0. better things to waste my time on !!
and to call that a GAME should be a Crime !!
rjp Offline
The way I understand it you can use a 32 head but you would have to get the 32 push rods cuz they are longer. And you will not have a org. 29 any more.
iagree
What are you trying to do with this information?
32 Confederate
Bruce S. DeFord
VCCA Judging Committee Chair
Some info BORROWED from VCCA posting
HEAD, CYLINDER
YEAR....CASTING..PART NO
1929.....835503...835674
1930-31..836273...836275
1932.....836718...836717
Gathering this info as a back-up plan JUST in case I can not Utilize the head/ configuration I currently have... checking my options :)
Read more here: 1929 Head Check - Valves
