#323065 11/02/14 04:32 PM
Gustave Offline OP
how many bulbs are there fro the instrument panel, 1941 Master Deluxe. I have done a search on this site, a general Google search, read over my 1941 manual. I cannot find anything. I have removed three 6 volt bulbs from the sockets. Two by the oil, temp, fuel, battery, and one by speedometer.
If Iremember correctly there are two in the speedometer. One on each side.
Gustave Offline OP
I can only find one. The other must be hidden.
However many there are replace them with #316 bulbs. They fit the sockets and are almost twice a bright as the OEM #55.
I replaced my dash and glove box bulbs with the # 316 `s....what a BIG differance ! you will like it! I got mine through www.memotronics.com they were very helpful and very inexpensive. Fast shipping .....In my `40 SD there are 3 in the instrument cluster like you said and 1 in the glove box....need to put one in the roof dome light too !
David Martin-Hendersonville NC, Pine Island Fl....... 1940 Chevy SDSS,
Check NAPA. I've bought several 6-volts bulbs at Napaautoparts.com.
Brandon Hughett
Powell, TN
1941 2-dr Town Sedan
If you look at the wiring diagram in your shop manual all the sockets are shown on each branch
