Posts: 549 |
Transmission rebuilder says the valve body assembly shaft grooves are warn? Needs a replacement but can't seem to find one? Needs to be Casting number 389443 GM4 Any body got a source?
"Frame Off" restoration, its a journey not a destination
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Check your G&D. There is a guy in there in the want ad's that sells rebuild parts. He may have a lead on a valve body.
I repaired the transmission on a 1961 and used a "Speedy Sleeve". Still running today.
Posts: 549 |
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
The Generator and Distributor Magazine that is another of the great benefits of being a member of the VCCA. Chevy Chatter is only one of the benefits of joining the Club. Join now and get ALL the benefits!!!
Posts: 1,072 |
there is one on ebay right now it has 17 holes that you can see the item #331261996900 casting number 369445 don't know that much about powerglide it could be what you are looking for
Posts: 549 |
Posts: 549 |
Looks identical but the dating numbers don't match which could be a problem Thanks
Do you have a VCCA member number? And do you get the magazine each month?
Posts: 549 |
Well, I thought that since you didn't know what the G&D was perhaps you were not a member. Is the missus hiding the mag when it comes? On another note I am also doing a 51 and your photos and thread are a great resource. I also agree with using a speedi-sleeve on your valve body. I've sold many of them in the heavy truck parts business and they can save a lot of $$$ and are very effective. Good luck with your repair and keep the photos coming.
