Camile Offline OP
My ventilation vent doesn't have all the parts connected that allows my vent to stay open. I am currently putting the latch on some wires to keep it open. I recently was given some of the original pieces to the latch that allows it to be adjusted. Can anyone share a photo of how the latch is connected underneath the dash? I'd appreciate it.
I assume you are referring to the cowl vent. Just in front of the windshield and behind the hood opennig......what year car?
Depending on what year you have, here is an example for the '37-'38 model year:
http://chevy.oldcarmanualproject.com/fisher/1937_38/3738fmcs005.html
~Jim
'38 Master Deluxe 2-Dr
*Disclaimer*...All technical advice given is for entertainment value only, and is not to be taken seriously...
That's one of the few areas I don't have pictures of. I have an extra setup in the garage. I'll see if it shows enough to help you out & snap a pic or two if it does.
Great find!! That saves me the job of crawling under the dash. What holds the vent open is the assembly down by the knob/shaft. It's a spring loaded ball that snaps into one of four holes shown on the hand lever. The hole at one end holds it closed, the other end holds it wide open & the other two are hold it between full open and full closed.
Camile Offline OP
Great article with pic!!! The guy gave me all of those parts in a box and said oh, here is the parts for the vent. LOL My truck is a '38. This helps a bunch!! Thanks beermugs
The picture is for a car. You have a truck which is different.
Camile Offline OP
You are correct. As I got uner and started looking I realized that my '38 truck is different that this car pic. Can someone take a pic of their truck linkage si I can see how it pieces together?
parking
