#32056 08/31/04 11:15 AM
What is the recommended fluid for the 1948 front shock absorbers? Thanks
#32057 08/31/04 04:43 PM
Hydralic jack oil
#32058 08/31/04 06:33 PM
I read on another forum (can't remember which one) that motorcycle shock absorber fluid would work.
The forum indicated that a person should use MEDIUM fluid to see if that works. If not, then either a lighter or heavier weight, depending on the outcome of using the MEDIUM fluid.
Hope this helps ..........
#32059 08/31/04 08:36 PM
Larry,
How about some Delco Hydraulic Shock Absorber Fluid. I have a 5 gallon can almost full.
#32060 09/16/04 05:07 PM
Chevs of the 40's also sells shock absorber fluid. Of course I bought a quart and will have enough left over for several lifetimes.
47 chevy bert
