Posts: 208 |
I noticed 2 levers on the "tree" of a 47 Im going to buy. I figure the upper one is the turn signal. Any one know what the lower one is for? they are both on the right side of the steering wheel Thanks
Blessings Bru Deut. 7:12
they are both on the right side of the steering wheel The only thing that should be on the RIGHT side of the steering column is the transmission shifter. The one exception would be the control arm for the special steering column control for the special radio. The direction switch should be on the LEFT side of the column. Any possibility of a picture so we can make positive identification?
Posts: 3,578 |
Yes try to post a pic.I have never seen the steering column radio control arm installed..It has to be what the second lever on the right is
Posts: 129 |
pic of my Super Deluxe Radio installed: ![[Linked Image from 1948chevy.com]](http://www.1948chevy.com/my48/conv20.jpg) ![[Linked Image from 1948chevy.com]](http://www.1948chevy.com/my48/conv23.jpg)
Posts: 3,578 |
Posts: 3,136 |
Don't get the two mixed up...Grin
Posts: 208 |
wow what a beautiful car, I hope my 47 conv. looks as good as this one day, but you're right,; I meant besides the gear shift lever, what is the lower lever? I see that on mine too. I just have pics, the car is being trucked to me in a few weeks. I cant seem to post a pic, cant remember how I got the the pic of my chevelle on here either; old age. thank you
Posts: 208 |
so how does the lower lever work for the radio?
The shaft sticking out on the right side is the steering column control for the 1946-48 special radio. Turning the knob top toward the dash turned the radio on and served as the volume control. If you pushed the knob toward the steering column it will cycle 5 pre-tuned stations. For a comprehensive report on the Model 985986 see the RADIO HOUR in the G&D May 1985. If you need radio work or a radio send me a PM.
Posts: 3,578 |
So Broo the question would be,does the car you purchased have a radio???
Posts: 129 |
But note that the Super Deluxe Radio shown in the pic has no buttons because the steering lever has the controls on it as stated above.
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
I noticed 2 levers on the "tree" of a 47 Im going to buy. I figure the upper one is the turn signal. Any one know what the lower one is for? they are both on the right side of the steering wheel Thanks Turn signal lever on the RIGHT SIDE of the column?
Posts: 3,136 |
I know...But, I think he has it figured out now from previous posts...Hopefully...lmao
Turn signal lever on the RIGHT SIDE of the column? As mentioned above, it is a steering column control for the radio.
Posts: 3,136 |
The turn signal would never be placed on the right...I have one (on the left), but prefer to use my arm...More "period" style...I guess...
Posts: 1,194 |
Buick did put the turn signal lever on the right in the 40's
If you CLICK on 48chevy.com you will find a picture of the radio and the control lever.
Posts: 1,069 Likes: 9
Posts: 1,069 Likes: 9 |
Younger people now probably don't know what the hand signals mean.
Posts: 3,136 |
Should be in the DMV Hand book...How could they pass the test without knowing...lol With luck, I'd guess...Most important is arm down...Means your slowing down...
Posts: 3,136 |
Buick did put the turn signal lever on the right in the 40's I'll have to check that one out...Not that I don't believe you...
Posts: 208 |
yes, the parts car has a radio & that lower lever Im going to use the steering from the parts car for the convertible, if it will fit.
Posts: 208 |
sounds great, I dont know if they work or not yet, & I still cant figure out how to put a pic here. send me a PM & I can send you a pic over the email Broo102
