Posts: 19 |
Hello. On the auxiliary wiper accessory for 1932, did it utilize a slave arm connected to the passenger side arm to be used with the single wiper motor?
Also was everything enclosed behind/under the windshield header board or was the slave arm connection exposed on the outside of the windshield?
One more question. On the Standard Sedan (32559), did it have Assist Straps or Pulls?
Thanks.
Kent.
The passenger side wiper arm/blade assembly had a separate pivot and linkage attached to the wiper motor. The linkage was hidden like the driver's side. The wiper motor was larger than the standard with single arm/blade.
Posts: 19 |
So if I understand correctly, a different motor would have been furnished with the "kit" then? If so was there a specific make and model?
Kent.
I don't know about any kit. Know what the two wiper motors (one replace the other) look like. I think I have at least one of each. If you have an earlier '32 it takes the one without the heart shaped cover later has that cover.
Posts: 1,919 |
If I understand correctly, there was a complete assembly which was installed to make the right side wiper work. But not for sure, would need to look at one. And I think the motor number was a SK2?
