#319348 09/24/14 08:25 AM
Twigs Offline OP
Is there a big difference in a 1940 Radiator vs a 1939 Radiator?
Being the one in my car now is a 1940 Olds Radiator...The Olds measure about 28" high x 18" wide and the core 3" thick but at the top tank it is about 4"
I can get a 1940 3 row copper and brass radiator
I'm not looking for Judge points being my shifter was put in the floor..
Thank you,
Twigs
1939 Chevrolet Master Deluxe 4dr sedan
VCCA# 50190
Twigs #319379 09/24/14 02:35 PM
The 1939 has a filler cap to the side , and a 1940 radiator has a filler cap centred. The 1939 has the hood hinge down the centre of the car, which is why the filler cap is needed to be on the side.
JACK
Twigs Offline OP
Ah ..yea...well I got a new 39 Rad coming...now the fun will begin..
Got the new Fan Belt installed too...
Thank you,
Twigs
VCCA# 50190
Twigs Offline OP
Jack would know what the hose sizes are for the 39...
Thank you,
Twigs
VCCA# 50190
Twigs #319386 09/24/14 03:21 PM
The top hose fitting measures 1 3/8" for 1 1/2" OD hose , and the bottom hose fitting measures 1 1/2" so would need a 1 3/4" OD diameter hose. Don't have my car handy to measure actual hoses , only a 1939 Radiator handy.
JACK
Twigs Offline OP
The top hose fitting measures 1 3/8" for 1 1/2" OD hose , and the bottom hose fitting measures 1 1/2" so would need a 1 3/4" OD diameter hose. Don't have my car handy to measure actual hoses , only a 1938 Radiator handy.
That's ok..Thanks for the info...
Wonder why the Parts Book states 1 1/4" and 1 1/2"..I can never believe what I read
Thank you,
Twigs
VCCA# 50190
Twigs #319388 09/24/14 03:27 PM
should read 1939 radiator handy.
JACK
Twigs Offline OP
Thank you,
Twigs
VCCA# 50190
Twigs #319390 09/24/14 03:46 PM
Hose diameters are quoted in the 1929 to 1950 parts manual as INSIDE DIAMETERS.
JACK
Twigs #319391 09/24/14 03:47 PM
Originally Posted by Twigs
typo which I corrected so shows as 1938 in your quote, but 1939 in my post.
JACK
Twigs Offline OP
Ah ..got it..Thanks Jack...
Don't know what I would do without my 1939 Buddies..
Thank you,
Twigs
VCCA# 50190
Twigs #319393 09/24/14 04:01 PM
Just to older topics, with the brakes on the rear, I pulled the rear brakes of a 1939 diff the other week, and both emergency brake link rods had the little spring on them.
JACK
Twigs Offline OP
Great to hear Jack..I made sure the springs were on mine this time.
Each day I learn something new about my 39..I have had it for 43 yrs now..It's my first car..
Thank you,
Twigs
VCCA# 50190
