Posts: 1,005 Likes: 5
Posts: 1,005 Likes: 5 |
How do you remove the horn button on a standard 1950 Chevrolet steering wheel?
Posts: 83 |
They are pressed fit. CAREFULLY pry it off with your fingers if possible. I have a broken one that says don't use a screwdriver.
rod
A thin stiff putty knife may help.
I got the horn button off. I used four putty knives and two wood shims. I got the two thinnest blades started on opposite sides - 3 and 9 o'clock. Then I started a wood shim to increase the gap - at 6 and 12 o'clock. I then inserted the next thicker blade until I could put two thinner blades in at the same point. I tapped on the wood shims to increase the gap again. Last step, I put the thicker blade between the two thinner blades and used it like a wedge. POP! it came off - and in ONE piece. The other important tool I forgot to mention was the extra large portion of patience.
