Posts: 2,306 |
The beige, plastic vacuum line for the water valve has broken in two. I assume that somewhere under the dash it is connected to a switch for the air conditioning/heating system? It has been 18 years since I did any work under my dash. What must I remove to locate the end of this line so I can replace it? Will I still be able to purchase the original style line or must it be replaced with a rubber hose? Thanks, Mike Yes, I have noticed that a lot of my engine does not look original. Some people do dumb things when they are young. Most days I wish I had left the engine all original. I think it is time to post in the parts wanted forum? ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_1598_zps9e4bb57b.jpg) ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_1599_zps57c43108.jpg) ![[Linked Image from i1321.photobucket.com]](http://i1321.photobucket.com/albums/u560/41chevymike/IMG_1601_zpsc80054a0.jpg)
As long as things arn't original I would slip a hunk of rubber tube between the plastic sections that remain. Being vacuum I would get hose with some "body" to it so in doesn't suck together.
Posts: 583 Likes: 1
Posts: 583 Likes: 1 |
I did just as Gene suggested to with rubber hose over the broken plastic hose when it broke on a similar era Buick, and again when it happened to my Fairmont. Its not pretty, but it works. That plastic tubing isn't available as far as I know.
-Daryl Scott #45848 • 1947 Chevrolet Fleetline Sportmaster Sedan • 1976 Chevrolet C20 Fleetside
Posts: 388 |
I repaired this brittle line 2 years ago using a small clear piece of hose from the heater control valve back to the pass hood hinge corner. The clear hose is much lighter than black rubber vaccum line.I zip tied the brittle oem line to a loom to stabilize it and let the clear line provide the flex.Been working great. Jim
Posts: 1,194 |
Just curious where the hose from the heater control valve goes? I can see in the picture that it goes back towards firewall on the right side. Thanks
Posts: 183 |
My recollection of the vacuum hose is that it is connected to the A/C heater control in the dash! Laying under the dash and looking up you should be able to find it. I worked for a Chevy dealer in '79, and never saw clear plastic tubing to the water control valve; it was always just plain rubber vacuum hose. The inner diameter was 7/32" I believe. You can easily splice it using a piece of 1/4" tubing or a plastic splice available at most parts stores. If you can have a buddy move the hose remaining under the hood you can pick up the hose under the dash and follow it, it just goes through a hole in the firewall.
flip
