Posts: 8 |
Any suggestion where I might find a new Carb float? Mine is not floating, filled with fluid and has been repaired a number of times.
1925 Roadster 1926 Landau Sedan 1941 Special DeLuxe 1969 Camaro
Posts: 8 |
FYI - I looked at The Filling Station and all they had was used floats that looked as bad or worse than mine.
I found a business locally that did a fantastic and reasonably priced ($65) job of building me a perfect new one. Every detail is correct. You can't tell even the slightest difference between the original and his except it is brand new. He can reproduce almost any carb part for any old carb out there.
I would post a pic but don't know how.
Randy
Posts: 3,511 Likes: 48
Posts: 3,511 Likes: 48 |
Randy, good deal!
You might want to forward your local supplier's contact info to the Filling Station as an 'FYI'.
Posts: 8 |
[img:center] ![[Linked Image from i1290.photobucket.com]](http://i1290.photobucket.com/albums/b540/autobahnracing/IMG_20140906_120416_371_zps6f7f1743.jpg) [/img]
Posts: 1,513 |
Looks like he does good work
