Hello all. Have been attempting to refurbish the tie rod on my 31 Coach and have a question about the tie rod ends. On my car they do not match - one is likely from some other year or model. The one that I think is correct seems to be a cast or forged part. The "shoulder" where the diameter increases is rounded and there is tapped hole (5/16"?) for a standard Alemite grease fitting. The other appears to be machined. The shoulder is square as if cut on a lathe and the hole for the grease fitting is much smaller, maybe 3/16". I think this one is incorrect for my car. Does that sound correct? If so, does anyone have a correct tie rod end for sale? I need the end that has the left-hand thread. As always, thanks for the help. Tom VCCA #5898
