Posts: 168 |
I have a '37 Master series 2 dr sedan that's all original. In the number 2 position from the left next to the headlight switch is a black pushbutton with a chrome bezel. I removed it from the dash and it has 1 spade type connector on the back and it looks like it has never been used and is a momentary contact. I have a horn button on the steering wheel and a stomp start so I rule out those possibilities. WHAT'S IT FOR???
Nothing that Chevrolet installed.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
My '38 had a chrome plug in the hole. I put a cat's eye lighter in it for a while then a stem light for the under dash voltmeter I installed. ![[Linked Image from i47.photobucket.com]](http://i47.photobucket.com/albums/f167/Tinys1938/IMG_1360_zpsfc9bcd10.jpg)
Posts: 327 |
Like the others said, it was probably an aftermarket pushbutton for something..maybe for another horn, light, siren, ejection seat, etc...
~Jim
'38 Master Deluxe 2-Dr
*Disclaimer*...All technical advice given is for entertainment value only, and is not to be taken seriously...
Posts: 1,558 |
Since you could get an accessory ash tray, I always thought that was where the lighter would go. Mine still has what appears to be the original chrome or nickel plug. Beamer
Posts: 1,774 Likes: 4
Posts: 1,774 Likes: 4 |
That is where the lighter is in my '37, it was there when I got it in 1967 but it is not the cats eye type it is probably a replacement or after market lighter.
Ed
