Camile,
First, like the others have said, is blowing the wrong way.
Second, it would seem to me that the electric fan is merely a Bandaid approach to an overheating problem. It's likely the problem will get worse over time and the extra fan won't help much.
I would suggest you determine the cause of the overheating problem and, then, after it has been fixed, toss the electric fan. You won't need it anymore.
The overheating is caused by one of the following in generally in order of top to bottom:
a. Radiator (partially stopped up)
b. Head Gasket (Blown - check for bubbles when water is still cold)
c. Cracked head (Ditto on bubbles)
d. Cracked block (Ditto)
e. Stopped up block (Blow some air through block cockpit hole)
f. Collapsing bottom hose (Not likely with the elbow, more likely with a single hose)
g. Bad Thermostat (You've already eliminated that one, it seems)
h. Timing
i. Friction if it's a newly rebuilt engine
i. Or a combination of some of the above
Note: I may have missed something: Gene JD, Chipper, Tiny, et al may have some suggestions as well.
You'll notice that I didn't mention the water pump. Usually the only thing that goes wrong with the water pump is it starts leaking.
Good luck with it.
Charlie
