Posts: 860 |
Anyone know where I can get the correct battery cables for my 48 Sport Coupe? The cloth type and the flat braided ground strap. Also; Is there another metal braided ground strap from the frame to the body?
hoppy
"Four-Doors-Forever"
Posts: 3,136 |
Try the filling station for your battery ground...You could find a cable for a block to frame ground or crimp one yourself...Don't know if it's necessary...I don't run one...
If your still running a 6 volt system...Again check the filing station or pick up some welding cable(oo) It's something like 17 and 1/2 inch's long...Won't find it at the auto parts store...Just don't settle for 12 volt cable...Not thick enough.
Posts: 766 Likes: 1
Posts: 766 Likes: 1 |
As mentioned above, The Filling Station or Chevs of the 40s both sell original style battery cables.
Dale Carter VCCA #8661 1948 Fleetmaster Convertible 1948 RHD Stylemaster Sedan Delivery 1948 1-Ton Tow Truck 1967 Camaro Coupe
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
This company should have the original cloth covered cable and woven ground strap in the correct gauge and color. http://www.riwire.com/
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Unless it's a show car try Tractor Supply. Charlie
Posts: 860 |
Thanks for all the suggestions, I think I will try calling Rhode Island Wiring tomorrow.
hoppy
Posts: 766 Likes: 1
