#312622 07/10/14 05:41 PM
dandyd Offline OP
I have noticed lately on Ebay valve covers advertised as 55-57 models, but they do not have off-set mounting holes. I have always thought that 1958 was the last year that the off-set holes were used. What is correct?
Wilwood Engineering1955-1957
dandyd #312630 07/10/14 06:30 PM
I read recently on the Tri 5 chat site that the offset bolt pattern ended mid year 1959 when the '58 engine inventory was finally depleted.
But can a guy really trust everything he reads on the Internet? (Wink wink)
1930 Roadster Delivery
1966 Chevy II 100 Series Station Wagon
TXWagon #312674 07/11/14 12:15 AM
Mid year 59, change in the cylinder head design I have the TSB somewhere, running out of 58 engines is pretty funny
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
The small blocks had an oil consumption problem. At first it was blamed on the rings. Then they discovered the oil was not returning from the top of the heads fast enough at high engine speeds and splashing on the valve guides. In 1959 they installed seals on the valve guides to wipe the oil off the stems. This didn't work so in mid 1959 they redesigned the head so the oil would return to the sump faster....this was a big help. The new heads were often installed under warranty on 1958's and early 1959's if the owner complained about oil consumption. Also if you bought a new head for a 1957 to early 1959 after 1959 you got te redsigned head. Then they made a "valve cover kit" that consisted of a correct valve cover and a couple of different length head bolts that were required when the redesigned head was installed.
Chev Nut #315293 08/10/14 05:34 PM
Way after 1959 .......
I purchased a NEW 1963 Impala Convert in 1963.
283 / 2bbl / P.G.
I can tell you the oil consumption was ENORMOUS.
Engine was pulled down, ring gaps not correctly aligned, was the diagnosis.
While a few 1963's used oil I would doubt that that was the problem but it sounded good to the customer.
We had some engines that just wouldn't stop using oil after all the usualthings were done. The final cure was to install a new short block. If it was under warranty you needed "permission" from GM.
Chev Nut #315318 08/10/14 10:01 PM
It was under warranty, but it wasn't fixed .... then, with my final decision, the oil barge was gone.
